ACS shell command to restrict access
Aug 19th, 2008
I am trying to set up groups within ACS to have "show" privilege only, per the below link.
I have ACS set up and working for the network from the admin group allowing all access and it is working fine.
When I follow the instructions to allow only "ReadOnlyAccess", I can log into the devices, but do not have "enable" access.
I get an authenitcation error:
"T+ enable privilege too low"
Do I need to allow "enable" as well in the shell command?
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml')
dhananjoy chowdhury Wed, 08/20/2008 - 01:58
  • Silver, 250 points or more
Under the Advanced TACACS options, set the Max privilege of level 1 or higher..
