how to configure SSH
olakunle06
please can anyone help on how to configure SSH on cisco router. i need help on the relevant commands to put on the router.a quick response would be highly appreciated.thanks a lot
It depends on what you need...
Massimiliano.
7 Replies 7
Look at http://www.cisco.com/en/US/docs/ios/12_2/security/configuration/guide/scfssh.html
I hope this helps.
Best regards.
Massimiliano.
PLS CAN I USE ANOTHER METHOD WUTHIS SSH CONFIG INSTEAD OF AAA NEW MODEL METHOD
Use aaa authentication ssh console local...instead of aaa new model
In this case you must define an user on your router.
I hope this helps.
Best regards.
Massimiliano.
pls could u help with a sample config. i will really appreciate it.
crypto key generate rsa
ip ssh
ip ssh version 2
aaa authentication login default local
username your_username password your_password encrypted
I hope this helps.
Best regards.
Massimiliano.
thanks for the quick response.
u mean the ip domain-name and hostname command is no longer neccesary.if it okay
should my hostname be thesame with the username.thanks for anticipated response
Massimiliano.
