HAPPY TO HAVE PASSED CCNA
Aug 19th, 2008
Guys i just want to thank you all for your post and advice which helped me pass the CCNA with a Score 960. I must say there is no doubt the post's here help a lot but you sometimes put so much fear in some of as who are just entering into the Cisco side of things.here is what i used
RICHARD DEALS BOOK AND
PACKET TRACER
arcolino11 Thu, 08/21/2008 - 12:58
did you have a lot of experience with routers and switches?
if I do not have access to routers and switches would you recommend the router and switchs sims? example boson?
GAFFARGHANA Fri, 08/22/2008 - 13:32
WELL I DID NOT USE ANY REAL EQUIPMENT APART FROM PACKET TRACER AND SOME FEW TIMES I USED BOSTON NETSIM. BUT I HAVE HAD MYT HANDS ON THE REAL EQUIPMENT AFTER THE EXAM AND I THINK THERE IS NOT MUCH DIFFERENCE. BUT IF YOU HAVE THE REAL EQUIPMENT IT WILL BE AN ADDED ADVANTAGE.
arcolino11 Fri, 08/22/2008 - 20:59
is the packet tracer real good?
better than boson?
can anybody use packet tracer?
where can I get it?
thx for the feed back.
pmc_kiran Fri, 08/29/2008 - 06:42
If you have any e-material, please forward it to me. I'm also preparing for the CCNA and I want to know the tips and tricks regarding the same.
