08-19-2008 05:00 AM
Hi, internet connectivity for lan gets disconnected after of VPN termination on ASA.(remote user needs to connect to ASA).even I cant telnet to ASA or internet router...when I restart the ASA then everything is fine.IOS is 7.0(6).
08-19-2008 06:52 AM
Without access and without seeing the problem, its hard to pin point the issue. So, here are somethings we can start with.
a. Can you send me the output of the following commands
sh run | in global
sh ip
sh run | in nat
sh run static
sh run | in crypto
b. When this problem happens, can you do "clear xlate" & "clear arp" - see if it works after that. Since you cant access the ASA via telnet, can you console into the ASA and issue those commands.
c. Last but not a perfect solution - since its blind troubleshooting..you are on a very old version of code. Can you please upgrade to 7.2.x version of code.
Please let me know if I can be more help.
Gilbert
08-19-2008 11:37 AM
IF possible post your crypto configs here, most probably your NAT exemption or crypto ACLs are mis-configured.
show run crypto
show run tunnel-gr
show run group-policy
Farrukh
