Cisco ACS SNMP
Aug 19th, 2008
We're running two ACS boxes (Release 4.1(4) Build 13 Patch 3). On of our boxes doesn't have the SNMP option available under Appliance Configuration, but our other does. Anyone know how to enable this? Thank you.
John
Premdeep Banga Thu, 08/28/2008 - 15:16
Probably you have an appliance that was not re-imaged with 3.3.3 CD, where SNMP was introduced and to have SNMP option, it was necessary to re-image. And you made all the remote upgrades and reached from 3.x to version 4.1.4.13.3 on your ACS SE.
To get this option,
- Take a backup of the database
- re-image ACS SE with 4.1.1.x recovery Cd for the appropriate platform, and then upgrade it to version 4.1.4, and then apply patch 3
- Restore the backup
Prem
Please rate if it helps!
