Managing a 1240 AP on other VLAN?
Answered Question
Aug 19th, 2008
I've set up a 1240 as AP with 2 VLANs, works fine. But our network uses VLAN 200 as management, not VLAN 1. I configured int BVI200 and gave it an IP address, but cannot get any IP connectivity. If I use BVI1, everything works, but on the wrong VLAN. How can I manage my AP on another VLAN?
Correct Answer by Scott Fella about 8 years 11 months ago
Use BVI1 and configure the switch port which is a trunk for native vlan 200. Give that a shot.
Overall Rating: 3 (1 ratings)
Correct Answer
Scott Fella Tue, 08/19/2008 - 06:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
PETER EIJSBERG Wed, 08/20/2008 - 08:08
Could not find other solution, so that is what I did: change the native vlan to 200. Thanks
I have the same problem in the network.
I use VTP Prunning in the network, and when configure the native vlan (200) in the interface trunk (Switch for AP), this generated another problem. All the vlans appear in the interface trunk on the switch, but this not is ok, because should appear only in the interface trunk the vlans as configurated on the access interfaces on the switch.
The situation appear because i have change the native vlan (Vlan 1 to vlan 200)on the switch.
What I can do for fix the problem?
