ACS 4.2.0.124.4 patch, cant upgrade
Aug 19th, 2008
upgrade from 4.2.0.124 to latest cumulative patch:
csupdate.exe is not a valid win32 application
Overall Rating: 0 (1 ratings)
kaskanna Tue, 08/19/2008 - 06:57
Hi Sobolev,
Before upgrading to patch 4, stop all the ACS services.
Extract zip file in ACS_INSTALL_DIR to replace with the new files.
Then Navigate to ACS_INSTALL_DIR\bin\ from command prompt and execute CSUpdate.exe -upgrade "ACS_INSTALL_DIR\CSDB\upgrade.dat".
[ Eg: C:\Program Files\Ciscosecure Acs v4.2\bin>CSUpdate.exe -upgrade "C:\Program Files\Ciscosecure Acs
v4.2\CSDB\upgrade.dat" ]
Note: Put the path in double quotes ("") if there are any spaces in the path name
Still if you face any problem, please revert back.
Kasthuri
m.sobolev Tue, 08/19/2008 - 07:00
been there, done that
...execute CSUpdate.exe -upgrade "ACS_INSTALL_DIR\CSDB\upgrade.dat" and I get my error...
