ASA5510 Need to add 25 Peer SSL VPN Licenses, NM found it link in this post
Answered Question
Aug 19th, 2008
I just received my new ASA5510 and also a Product Authorization Key for "ASA 5500 SSL VPN 25 Peer License" But I cannot for the life of me figure out how to install these licenses. I tried to enter the key supplied but when I do the ASA returns an error "enter 4 or 5 Tuple Activation-Key"
Is there some place on Cisco's site where I "activate" this key to get an installable license on the ASA?
https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet
Thank you,
Rick
Correct Answer by Farrukh Haroon about 8 years 6 months ago
Once you put your PAK code on the page you mentioned, it will ask you to verify the end-user and contact information. At the end of the process (step 4) you will receive an email with the activation key. Then just enter it on the ASA using the activation-key command (detailed instructions will be present in the email as well on how to do this).
Please rate if helpful.
Farrukh
Overall Rating: 5 (1 ratings)
Correct Answer
Farrukh Haroon Tue, 08/19/2008 - 12:29
Farrukh
