Marwan ALshawi Tue, 08/19/2008 - 07:36
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
if u mean u want to send a call to an fxs from plar u need a pots dial peer
lets say u have fxs port 0/0/1 with number 222
diap-peer voice pots
destination-patren 222
port 0/0/1
and lets say ur fxo port is 0/1/0
do
voice-port 0/1/0
connection plar-opx 222
this way the call coming into the fxo will go directly to the fxs
IF u want the FXS to make a dirct dial when u just pick up the phone do the following on the FXS
voice-port 0/0/1
connection plar 333
call will go to number 333 but it need a
voip dial-peer to ur call manager
forexample
dial-peer voice 9 voip
destniation-patren 33.
session target ipv4:[ur CCM IP]
i am asuming u r usin H323 gateway
good luck
please, if helpful Rate
Rafael Jimenez Tue, 08/19/2008 - 08:18
one more question, if i have configured SCCP gateway for all my 6 fxs ports in the EVM module .
Must I unconfigure the port that i need for connection plar ?.
Can I leave the fxs port controlled by the call manager via sccp and add the plar command en the voice port?.
Thanks.
Marwan ALshawi Tue, 08/19/2008 - 16:12
i havnt worked with gateway
but as long as it is controled by the CCM try to find an optionin the port setting
or u can make the same idea as the document u have
good luck
Marwan ALshawi Tue, 08/19/2008 - 21:56
sory i didnt mean with a gateway i meant with that gateway type u use :))
