7971GE rejects repeat /CGI/Screenshot when lightly loaded...
I realize this may be more appropriate for another forum (I'll post there as well) - but my 7971GE phone starts rejecting connections after a series of screen snapshots /CGI/Screenshot EVEN 30 seconds apart...
I've attached a test program that you can run...it just loops and executes a screenshot every x milliseconds...
java testphone 30000 yourIP
The 7940 does not seem to have this problem
Test Program Source (I keep getting content type of xxx.java not allowed):
import java.io.*;
import java.awt.*;
import java.awt.image.*;
import java.net.*;
import javax.imageio.*;
public class testphone
public static void main(String[] args)
int count=0;
if(args.length==0) {
System.out.println("Usage is: java testphone iter gap ip");
System.out.println("Example: java testphone 50 10000 192.168.7.120");
System.exit(0);
for(int i=0;i<Integer.parseInt(args[0]);i++) {
try {
count++;
String myFile="test"+count+".gif";
System.out.println("Creating Snapshot "+myFile);
new testphone().doit(args[2],myFile,"any","any");
System.out.println("Done Creating Snapshot "+myFile);
catch(Exception e) {
System.out.println("Crashed: "+e.toString());
try { Thread.sleep(Integer.parseInt(args[1])); } catch(Exception e) { }
public void doit(String theIP,String fName,String User,String Pass) throws Exception
URL url = new URL("http://"+theIP+"/CGI/Screenshot");
HttpURLConnection conn = (HttpURLConnection)url.openConnection();
conn.setReadTimeout(5000);
conn.setConnectTimeout(5000);
conn.setDoInput(true);
conn.setDoOutput(true);
conn.setRequestMethod("GET");
conn.setRequestProperty("Content-type","application/x-www-form-urlencoded");
String theAuth=User+":"+Pass;
theAuth=new sun.misc.BASE64Encoder().encode(theAuth.getBytes());
conn.setRequestProperty("Authorization","Basic "+theAuth);
BufferedImage image=ImageIO.read((InputStream)conn.getInputStream());
File NewFile = new File(fName);
ImageIO.write(image, "gif", NewFile);
agiaccone Wed, 08/20/2008 - 08:36
Hi, maybe you could find some additional info looking at the phone's log :
http:///CGI/Java/Serviceability?adapter=device.statistics.consolelog
Hope this helps,
Alberto
