VPN Tunnel between ASA and ISA Server 2004
Aug 19th, 2008
I have an environment with ISA and ISA server 2004 and I am trying to create a vpn site-to-site between them, the tunnel is created as output of command "sh isakmp sa," but not anything happening in the tunnel, or the ping command or via terminal services that the tests that were performed, ISA server logs shows the connection initiate but not complete, I am called support to open in microsoft to investigate but would like to think of you below the topology and settings already checked several times in the settings ASA and ISA Server are identical in both the policies of IPSEC and IKE, if anyone have any idea of what might be wrong now thank you.
asa# sh isakmp sa
Active SA: 1
Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1 IKE Peer: 10.0.0.167
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
asa#
regards.
