CSM - DCR Wizard
Aug 19th, 2008
All,
Trying to integrate CSM 3.21 with LMS 3.01 to share DCR.
I have:
> Ensured CSM and LMS identity accounts and peer accounts setup correctly
> Imported Peer Certs from CMS to LMS and vise-versa
> Setup LMS as DCR and Single Sign-On Master
> Setup CSM as DCR/SSO Slave to LMS
> Registered CSM applications into homepage config of LMS
> Configured CSM Client to use LMS as its RME server
This all seems to work fine, but I still don't have a populated device list in CSM client.
User logs into CSM client and no devices are listed, they only have the option to Add devices from a file etc as per screenshot.
Looking at the following:
http://www.cisco.com/en/US/docs/security/security_management/cisco_security_manager/security_manager/3.1/user/guide/ivman.html#wp1449656
It suggests there is a DCR Device Wizard and says:
You can access the Device Information page from the Add Device from DCR wizard. Click the Add button in the Device selector, select Add Device from DCR, then click Next.
I don't get an "Add Device from DCR" option (see attachment).
THe only option I seem to have related to DCR is the "Add Device From File", which requires doing an export from DCR to a CSV file - not very secure for a security product as the DCR export contains all the device credentials!
Michael
Have I missed a step or doing something wrong not to get this option?
