HWIC-4ESW for Cisco 2851
Answered Question
Aug 19th, 2008
I want to add layer 3 router interface on C2851. I did a search and find the following part number"
HWIC-4ESW
Four port 10/100 Ethernet switch interface card
My quesions is:
Will the 4 ethernet ports share just one layer 3 interface or they are 4 seperate layer 3 interfaces?
Correct Answer by Richard Burts about 8 years 8 months ago
YUHUI
The 4 Ethernet ports in the HWIC-4ESW are layer 2 ports. You can put all 4 ports into a single VLAN and have a single layer 3 interface if you want. Or you can put each port into a separate VLAN, define 4 VLAN interfaces, and therefore have 4 layer 3 interfaces.
It is quite flexible and the results will reflect what you want it to do.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Tue, 08/19/2008 - 10:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
YUHUI
Rick
yuhuiyao Tue, 08/19/2008 - 10:31
Rick,
How can I configure it? There seemed no vlan configuration available on a C2851 router.
Richard Burts Tue, 08/19/2008 - 12:08
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
YUHUI
I hope that you will find this link helpful about configuring the HWIC-4ESW:
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_hwic_ethsw_ic.html
I believe that you need to first configure the ports on the switch as access ports and assign each port to a different VLAN
SUMMARY STEPS
1. enable
2. configure terminal
3. interface fastethernet interface-id
4. shutdown
5. switchport mode access
6. switchport access vlan vlan-num
7. no shutdown
8. end
and then you configure VLAN interfaces and assign each VLAN interface its own ip address and mask
1. enable
3. interface vlan_id
4. ip address ip-address subnet-mask
5. end
Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read about an issue and can know that there were responses which did resolve the issue.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
yuhuiyao Tue, 08/19/2008 - 12:15
This is a switch module, and those 4 ethernet ports are not visible in the router.
Can I have those 4 ethernet visible on the router?
Richard Burts Wed, 08/20/2008 - 04:32
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
YUHUI
I am surprised at that. Does the router see the switch module? What does show version indicate and perhaps the output of show diag.
From the link that I posted is a requirement for version of software:
Use of the Cisco IOS T release, beginning with Release 12.3(8)T4 or later for Cisco HWIC-4ESW
what version of software are you running on this router?
Rick
