CiscoWorks Login Screen
Answered Question
Aug 19th, 2008
Using LMS 3.0.1. Is there anyway to customize the initial login screen? We would like to put a banner on it similar to what is displayed when logging into a switch. Thank you.
Correct Answer by Joe Clarke about 8 years 9 months ago
N, there is no way to add such content to the login screen. This would be an enhancement request that you should take up with your account team. I can see this being useful to a few customers.
Overall Rating: 3.7 (4 ratings)
Correct Answer
Joe Clarke Tue, 08/19/2008 - 11:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
mikecrowe4ics Mon, 10/12/2009 - 20:00
I see that this reply is about 1 year old now, and LMS is now up to version 3.2.
An example of customers that this would help would be the US Department of Defense. They are required to use a standardized warning banner on all systems.
Even a customized message of the day (MOTD) area would be a great improvement.
Does this answer still apply to LMS 3.2? Is there still no ability to customize the login screen in any manner?
Joe Clarke Mon, 10/12/2009 - 20:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Nothing has changed in LMS with regard to this feature.
Martin Ermel Fri, 01/15/2010 - 07:56
  • Blue, 1500 points or more
an undocumented feature of LMS might help you in this case. I found it while digging in the filesystem of NMSROOT.
make a backup of the following file then open it in a text editor:
NMSROOT\lib\classpath\cscommon.properties
enter the message between the double quotes of the parameter CUSTOM_LOGIN_MESSAGE. It should looks like this:
CUSTOM_LOGIN_MESSAGE="your message for everyone who login to LMS"
Save the file and be careful that you DO NOT CHANGE the file extension!
No reboot required.
Now, everyone that successfully login to LMS gets a pop-up with this message.
