FXS SCCP ports are not receving calls
Aug 19th, 2008
I have an EVM module in a 2821 with 8 fxs ports. I setup the 8 fxs ports as a sccp gw in my cucm6.1.. I can dial to the ip phones from the fxs port, but dialing ip-phone to fxs is not working..... what is the problem?. Transcoding?.
I have defined a media resource list for xcode with the cucm first followed by the dsp resources associated with the dspfarm @ gw.
Also I feel a timeout problem with the fxs, looks like do not release the ports after a call, some time works,some times do not work.
1. (fxs->ip phone work so so...)
2. (ip-phone->fxs do not work!!!).
Thanks for your help.
Rafael Jimenez Thu, 08/21/2008 - 09:16
To share this information with all people. My problem was the IOS doest support stcapp. I had to change the ios and implement the all remaining programming...service stcapp, sccp plar ...etc.
Following the cisco recomendation i setup the 1.e1-cas r2 with h323
2.fxo's with mgcp
3.fxs's with sccp.
I had to setup the service stcapp in the voice ports ..
