unable to connect to VPN server with Port redirection
Aug 19th, 2008
Hi. I am trying to forward traffic to our VPN server. device is an ASA 5505 running v7.2
I have followed these directions from cisco that were taken from the URl:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094a5a.shtml
I even tried to setup a VPN server on the asa, just to test, using a simple pre-shared key.
Here is my config
dns server-group DefaultDNS
domain-name *-
access-list outside_access_in extended permit gre any host x.x.x.26
access-list outside_access_in extended permit tcp any host x.x.x.26 eq pptp
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPN 192.168.0.40-192.168.0.45 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) x.x.x.26 192.168.0.20 netmask 255.255.255.255
access-group outside_access_in in interface outside
route inside 192.168.104.0 255.255.255.0 192.168.0.249 1
route inside 192.168.107.0 255.255.255.0 192.168.0.251 1
route outside 0.0.0.0 0.0.0.0 x.x.x.25 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.0.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set TRANS_ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_3DES_SHA mode transport
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set TRANS_ESP_3DES_SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.0.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server value 192.168.0.2 192.168.0.3
vpn-tunnel-protocol l2tp-ipsec
default-domain value *.com
username * password privilege 0
username * attributes
vpn-group-policy DefaultRAGroup
tunnel-group DefaultRAGroup general-attributes
address-pool VPN
default-group-policy DefaultRAGroup
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
tunnel-group DefaultRAGroup ppp-attributes
authentication ms-chap-v2
prompt hostname context
Cryptochecksum:xxx
: end
nyhq-asa00#
ghylandcit Wed, 08/20/2008 - 05:56
Sorry,
Yes I am using PPTP on a microsoft 2003 server setup for VPN. From what I gather, the only two two ports you need to worry about are tcp pptp(1723) and IP GRE(47). I can connect to the server from a computer when i try inside, and it works fine. its just that ports don't seem to be forwarding. I tried to just forward 3389(remote desktop) to another server, and I still had an issue. I have done this succesfully on an older pix, but this is my first time with an ASA.
acomiskey Wed, 08/20/2008 - 07:19
  • Green, 3000 points or more
Is x.x.x.26 also your outside interface address? If so, change
to
static (inside,outside) interface 192.168.0.20 netmask 255.255.255.255
