throughput estimation
Aug 19th, 2008
i have a 100Mb ethernet WAN connection between two sites. I'd like to calculate the throughput. I was trasferring some a 50Mb file over the link and only getting 70,000 bytes per second.
Overall Rating: 3 (1 ratings)
Tshi M Tue, 08/19/2008 - 14:00
Yes, we are currently transferring a 900M file and it is estimating 4 hours to finish.
Tshi M Tue, 08/19/2008 - 14:40
I think that could be the problem but I am not sure. The other end where the server is connected, the interface to auto/auto because that is how the vendor wants it. So it is actually showing at 100 half with tons of collisions.
Tshi M Tue, 08/19/2008 - 14:45
the problem is definetely with the server interface on the switch. I just tried using a different server that is configured for hard coded 1G/full and the performance is much better.
