Switch 4507R hardware architecture
Answered Question
Aug 19th, 2008
I am concern about how a switch 4507R connects each card to its backplane. I have two, and I want to be sure I am using the backplane speed correctly. I mean, if I connect all my servers to just one card, will I have performance issues? I read a slot has 6Gigs, does this mean I should distribuite my server across all the cards?
Thank a lot for any link to find the information I need, or any comment to clarify this.
Correct Answer by ropethic about 8 years 8 months ago
attached
You are correct each slot has six 1G FDX (12G)connections to the Supervisor switch fabric. It depends on the line card being used. If using a 24 port 4524-GB then you have a 4:1 over subscription. with a 48 port linecard 8:1 over - subscription. Should all ports be bursting at same time, guaranteed rate of 125Mbps for 8:1 and 250Mbps for 4:1. Keep in mind also, depending on supervisor throughput ranges from 48Mpps (Sup II+) (packets per second) to 102Mpps (SupV-10GE)
I would try and measure the amount of traffic to/from the servers to determine if over -subscription is an issue.
Most application servers (exceptions may include ftp, backups) rarely sustain gigabit rates over a extended periods.
Overall Rating: 5 (2 ratings)
Correct Answer
ropethic Tue, 08/19/2008 - 16:29
  • Silver, 250 points or more
hugopicado Tue, 08/19/2008 - 16:55
Thank you very much.
So I will take care of my backup server and the server it is backing up now, and the servers that make heavy data replication.
Do you have any link where I can read more architecture related information? Things like queueing and other are interesting to me.
I have a SupIV
Thank you again.
