IPSEC/SSL Connections
Aug 19th, 2008
I have a ASA 5510, we have both IPSEC and SSL setup on it, the users authenticate to a radius box. We would like to find out if there is a way to block users from using the IPSEC client (except for a certain few) and make everyone else use the SSL which then does a host checker and make sure they are clean before coming inside. Can this be done?
Thanks for the info
