compare Callmanager 4.x with 6.x
Aug 19th, 2008
Hi All;
do you guys have a compact chart or table that compares callmanager 4.x with 6.x regarding all telephony and networking features?
very appreciate if you send this document.
Overall Rating: 5 (2 ratings)
Rob Huffman Tue, 08/19/2008 - 16:16
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alex,
I have never seen a nice chart like you noted, I did summarize the changes recently between 4.1, 4.2, 5.x and 6.x :)
Cisco CallManager 4.1(3)
•Operating System Installation Guidelines
•Upgrading to Cisco CallManager Release 4.1(3)
•Call Pickup and Group Call Pickup Enhancements
•Call Transfer Enhancements
•New Feature Support with Cisco IP Manager Assistant
•New Service Parameter to Enable Music On Hold and Annunciator Duplex Streaming
•Updated Support for Cisco IP Phones
•New Hunt Pilot Configuration Parameters for Automated Alternate Routing
•Support for Annex M1 over H.225 Trunks and H.323 Gateways
•Security Enhancements
•Bulk Administration Tool Enhancements
•Dialed Number Analyzer Enhancements
•New and Changed Information for Cisco CallManager Serviceability
•New and Changed Information for Third-Party and SDK Applications
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/4_1/cucm-rel_notes-413.html#wp1708005
CCM 4.2.x New Features
New and Changed Information for Cisco CallManager Features CCM 4.2
The following sections describe new and changed information related to Cisco CallManager features:
Multilevel Precedence and Preemption Enhancements
Device Mobility
Cisco CallManager Attendant Console and Call Pickup Limitation
** Call Pickup Notification
** Directed Call Park
IPMA Enhancements
Cisco Messaging Interface Enhancements
Call Forwarding Enhancements
Password Management Features
** Log Out of Hunt Groups
** Voice-Mail-Related Changes to Hunt List and Hunt Pilot
New MLPP Service Lockout Enterprise Parameter
Phone Button Template
Call Diagnostics and Voice Quality Metrics
Overlap Sending and Receiving for H.323 Gateways
SDL Traces
Cisco CallManager T1 CAS Hookflash Transfer Support
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a00805f1470.html#wp2430214
continued on next page......
Rob Huffman Tue, 08/19/2008 - 16:17
  • Hall of Fame,
    Founding Member
....from previous page
here is the related CCM 5.x and CCM 6.x info :)
Cisco CallManager 5.x Features
Call Park
Call Pickup Group
CTI and CTI Super Provider
Dynamic Host Control Protocol (DHCP)
International Dial Plans
LDAP Directory Enhancements
Licensing
Personal Directory Enhancements
Phone NTP References for SIP Phones
Presence
Roles and User Groups
RSVP
Service Enhancements
SIP Line Side (Endpoints) Support
SIP Route Pattern
SIP Third-Party Phones
SIP Trunk Enhancements
TFTP Enhancements
URL Dialing
Video Telephony Enhancements
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/5_0_1/501cmrn.html
Cisco Unified Communications Manager 6.0 feature enhancements:
•AAC/iLBC Voice Codec Support
•Advanced Ad Hoc Conference
•Audible Message Waiting Indicator
•Barge Enhancements
•Call Diagnostics and Voice Quality Metrics
•Call Forward Enhancements
•Call Forward All Calling Search Space Backward Compatibility
•Call Forward Overriding
•Call Pickup Notification
•Cisco Messaging Interface Enhancements
•Cisco Unified Communications Manager T1 CAS Hookflash Transfer Support
•Connected Number Display
•Credential Policy and User Authentication
•CTI Enhancements
•Device Mobility
•Directed Call Park
•Do Not Disturb
•Hold Reversion
•Intercom
•Licensing Enhancements
•Log Out of Hunt Groups
•Overlap Sending and Receiving for H.323 Gateways
•MGCP T.38 Enhancements
•Privacy on Hold
•Programmable Line Keys
•SCCP Optimization
•SDL Traces
•SIP Endpoints Support
•SIP Third-Party Phones Enhancements
•SIP Trunk Enhancements
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_0_1/601cmrn.html#wp44812
Hope this helps!
Rob
Chris Deren Wed, 08/20/2008 - 06:19
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
To add to Rob's exhausting list (+5 points), here are additional features introduced in CM 6.1 from 6.0.
- DB Resiliancy
- Intercom for Cisco Extension Mobility
- Join Across Lines
- Single Button Barge
- System Reporting
- SIP Trunk Identification
- Thai Language Support
- Turkish Language Support
- Several new service parameters
Also, here is a preview of some of the new features coming up in CM 7.0
• Route lists now reference plan and type, so these may be reset on a route list basis
• Route pattern search now references "Associated Devices"
• Phone modification page now integrates easily to registered devices report
• Device pools now support calling/called party transformations
• Local route groups
• The gateway configuration screens now allow you to change an MGCP device type
• Mobile connect supports a single key turn-off: you can optionally tie DND to mobile connect. So, when DND is on, mobile connect is off.
• Time of day access is present in mobile connect
• IP phone services can be assigned enterprise wide as part of service creation.
• Directed call pickup: using the GPickup key and by dialing the DN of any other device on the system, you may pickup a call ringing on it.
• Alerting BLF
• Pickup BLF
• DND reject
• BAT support system import and system export
HTH,
Chris
Rob Huffman Wed, 08/20/2008 - 06:25
  • Hall of Fame,
    Founding Member
Hey Chris,
Nice! Looks like some great new features coming down the pipe in CCM 7.0 I have heard great things about this release. If you don't mind me asking, were/are you part of the EFT for 7.0?
Thanks for adding to this list (+5 for sure :)
Take care,
Rob
Chris Deren Wed, 08/20/2008 - 06:32
  • Hall of Fame,
Rob,
Yes, I've had it running in my lab for few months. The Local Route Groups feature is huge and I love it. It will essentially allow you to create global route patterns/paritions/CSS as oppose to site specific, for multisite deployment this is huge and will natively support routing 911 out of local branch in case of CER failure, I've actaully mocked it up and it works as advertised, really COOL.
Dial plan normalization (+) is fianlly here as well, which make CUPS/OCS integrations a lot better, you can really get crazy with this and easily complicate things :-) Other than that as mentioned above some new features, but look and feel is the same as 6.1.
Chris
