How to find out existing ICM Instance Number
Answered Question
Aug 19th, 2008
Hi All,
I need to add new PGs to the existing IPCC Environment.
However, i'm not sure what the instance number is the existing IPCC Servers are configured.
Is there anyway to find out the existing instance number without disrupting the existing environment?
Erwin
Correct Answer by cvenour about 8 years 7 months ago
You can also find it on any existing ICM server using Regedit:
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\ICM\\CurrentVersion\InstanceNumber
Do note that if you are adding new PGs into a 7.x environment that the setup will collect the instance information from the Domain Controller, and provide you with a drop down list to select from.
C.
Correct Answer by Adam Thompson about 8 years 7 months ago
You should be able to find your instance information by using the Configuration Manager utility. Under Explorer Tools, you should see a sub-heading for ICM Instance Explorer.
-Adam
Please rate if helpful
Overall Rating: 5 (2 ratings)
Correct Answer
Adam Thompson Wed, 08/20/2008 - 08:50
  • Silver, 250 points or more
-Adam
Correct Answer
cvenour Wed, 08/20/2008 - 17:49
C.
