EIGRP Holdtime value on GRE tunnels
Aug 19th, 2008
Greetings All,
What is the recommended EIGRP holdtime value on GRE tunnels. I have a backup link using ipsec/gre that goes thru the internet. Earlier today we had an outage that caused us to use our ipsec/gre internet backup link. Everything would have been great but for some reason EIGRP ajacency kept on flapping during that time so the back up link was almost useless. Im not sure if it was load that caused the peers not to respond to the hello's in a timely fashion or if was something else. (without load the adjacency is stable)
royalblues Wed, 08/20/2008 - 03:22
  • Green, 3000 points or more
Did you ever receive the following logs during the EIGRP flaps - The %TUN-5-RECURDOWN
This happens when the route to the tunnel destination address using the tunnel interface itself.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094690.shtml
The neighbors can also flap if there is some instability in the network path but i think th default hold timer for EIGRP (i.e15 secs) should be fine even if you have a latency of around 300ms between the neighbors.
Narayan
Richard Burts Wed, 08/20/2008 - 03:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Merrylle
I have had somewhat similar experience with EIGRP running over IPSec GRE tunnels at a customer site. We changed the EIGRP timers to 15 and 45 and it seems to be more stable.
Rick
