Changing BGP AD on routes from specific AS
Aug 19th, 2008
Hi All.
Is it possible to change the Admin Distance on eBGP routes (using 'Distance' cmd, I guess), but only from a specific AS?
IOS 12.2SX
I guess what I'm looking for is the Distance cmd to reference a route-map instead of an ACL.
Cheers
David
Overall Rating: 4 (1 ratings)
royalblues Wed, 08/20/2008 - 05:52
David,
What is the need for changing the AD for Ebgp for some specific routes?
If you are trying to do this to modify routing preference, then there are lot of other attributes which you can use with BGP
Narayan
dlongworth Sun, 09/07/2008 - 17:35
Hi Narayan,
I have a preference for certain EIGRP routes to be chosen over their BGP equivalents but it'd be simpler if I could reference the origination AS instead of a few hundred routes.
Edison Ortiz Sun, 09/07/2008 - 18:16
In that case you can do it under EIGRP but only for internal EIGRP routes, you can't do it under the BGP routing process.
See a sample in my lab:
I want to make 10.1.2.2 an EIGRP route:
Rack1R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
192.168.12.0/30 is subnetted, 1 subnets
C 192.168.12.0 is directly connected, Serial1/0
20.0.0.0/32 is subnetted, 1 subnets
B 20.1.2.2 [20/0] via 192.168.12.2, 00:03:41
10.0.0.0/32 is subnetted, 1 subnets
B 10.1.2.2 [20/0] via 192.168.12.2, 00:03:41
150.1.0.0/32 is subnetted, 1 subnets
B 150.1.2.2 [20/0] via 192.168.12.2, 00:03:41
____________________________
access-list 1 permit 10.1.2.2
router eigrp 1
network 192.168.12.1 0.0.0.0
distance 19 192.168.12.2 0.0.0.0 1
no auto-summary
_______________________________________
Rack1R1#sh ip route
B 20.1.2.2 [20/0] via 192.168.12.2, 00:03:51
D 10.1.2.2 [19/2297856] via 192.168.12.2, 00:00:07, Serial1/0
B 150.1.2.2 [20/0] via 192.168.12.2, 00:03:51
HTH,
____
Edison.
Please rate helpful posts
dlongworth Sun, 09/07/2008 - 18:47
That does help, thank you, but unfortunately I do need it also for EIGRP external routes.
Edison Ortiz Sun, 09/07/2008 - 20:01
Hi David,
Too bad, this can only be done with internal EIGRP routes.
You can't use the distance command within a route-map for BGP routes.
__
Edison.
mrosasco Mon, 09/08/2008 - 04:17
Hi.
you can use the network backdoor command, under bgp, for this routes.
It's for this problem.
sdoremus33 Wed, 09/10/2008 - 08:01
Perhaps you could use the network backdoor command to influence the route
