Citrix Plugin SSL VPN
jtphilies Fri, 08/29/2008 - 04:09
Hi, with the ctx plugin you cant publish applications as it just generates you an ica session from the ASA.
We publish our server desktop, but publishing an app with be the same principle.
What you would need is a Ctx Secure Gateway server or Web Interface server in your DMZ (behind the FW) then for your WEBVPN create a bookmark that points to the webinterface in the dmz. This launches the webinterface login page, authenticate and you will see the published app.
good luck
