WAAS exporting tfo logs via sftp
Aug 19th, 2008
Hello
Running WAAS 4.0.19.
I've stuck an issue where the CLI command on an edge WAE:
transaction-logs export sftp-server 10.1.1.1 tst1wae01 password logs/raw
...is accepted but when you then try and use the Transaction Logs page of that WAE in the Central Manager's GUI and make a different change (say the interval), the GUI throws up an error:
"Directory1 must start with forward slash"
If I put a forward slash in at the GUI and save it, the export will fail.
The export works when I force the WAE to use the line specified as per the CLI. If I do this the GUI shows the path as "logs/raw" which is what I want.
Anyway, the work around works but it is annoying because I effectively cannot use the GUI page for transaction log changes.
Has anyone else seen this?
Cheers
Cameron
Overall Rating: 5 (1 ratings)
Zach Seils Thu, 08/21/2008 - 09:45
Hi Cameron,
Why does the export fail with a leading / in the path? Is that not a valid path on the target server?
Can you perform the following debug and send the syslog.txt file:
From config mode:
logg disk prior debug
From enable mode:
transaction-log force export
Zach
cstockwe Thu, 08/21/2008 - 17:20
Hi Zach
It looks like that the SFTP server's directory I was supplied is not an absolute path. If I put in the absolute path "/home/tst1wae01/logs/raw" it works ok.
I suppose the strange thing that I was raising was the fact that the CLI will accept a command without the leading '/' but the central manager GUI won't.
