VPN Client config
ntmanjunath
How to configure VPN Client in Cisco router and let me know the sample configuration.
the config looks ok now
but as i told u
o the client vpn software there is group name and password
put the group name as admin and pasword as admin 123
once the phase one of the vpn setup done u will be prompted to enter username and password in this stage use one of the username and password u created such as
manju and pass cisco
good luck
please, if helpful rate
and let me know if worked or not
12 Replies 12
Marwan ALshawi
Can you please give simple configuration for VPN client? This would be more complicated.
Just for two to three user can access.
RTRA(config)# aaa new-model (1)
RTRA(config)# aaa authentication login vpnclient local
RTRA(config)# aaa authorization network localgroups local
RTRA(config)# username user1 secret user1
RTRA(config)# username user2 secret user2
RTRA(config)# username vpnuser secret 12345
RTRA(config)# crypto isakmp policy 10
RTRA(config-isakmp)# encryption aes 128
RTRA(config-isakmp)# hash sha
RTRA(config-isakmp)# authentication pre-share
RTRA(config-isakmp)# group 2
RTRA(config-isakmp)# exit
RTRA(config)# crypto isakmp keepalive 20 3
RTRA(config)# ip local pool pool1 192.168.0.200 192.168.0.219
RTRA(config)# ip access-list extended splitremote
RTRA(config-ext-nacl)# permit ip 192.168.0.0 0.0.0.255 any
RTRA(config-ext-nacl)# exit
RTRA(config)# crypto isakmp client configuration group admin
RTRA(config-isakmp-group)# key admin123
RTRA(config-isakmp-group)# pool pool1
RTRA(config-isakmp-group)# domain cisco.com
RTRA(config-isakmp-group)# acl splitremote
RTRA(config-isakmp-group)# exit
RTRA(config)# crypto ipsec transform-set clienttransform esp-aes esp-sha-hmac
RTRA(cfg-crypto-tran)# exit
RTRA(config)# crypto dynamic-map dynmap 10
RTRA(config-crypto-m)# set transform-set clienttransform
RTRA(config-crypto-m)# exit
RTRA(config)# crypto map mymap client authentication list vpnclient
RTRA(config)# crypto map mymap isakmp authorization list localgroups
RTRA(config)# crypto map mymap client configuration address respond
RTRA(config)# crypto map mymap 1000 ipsec-isakmp dynamic dynmap
RTRA(config)# interface Ethernet0/0
RTRA(config-if)# description Local LAN
RTRA(config-if)# ip address 192.168.0.1 255.255.255.0
just change the ip addresses to ur IPs
if u need any more details post it here
if helpful Rate
HI
When I try to connect VPN Client its shows the below said reason.
reson 414 failed to establish a TCP Connection
Usename admin
password admin123
MY ROUTER CONFIGURATION
sh run
Building configuration...
Current configuration : 1405 bytes
version 12.4
hostname AIRTEL-DELHI
boot-start-marker
boot-end-marker
logging buffered 4096
aaa new-model
aaa session-id common
ip cef
username manju secret 5 $1$mMhL$NYG27PsAEJ3vUB6CwoqGs.
encr aes
group 2
crypto isakmp keepalive 203
key admin123
domain cisco.com
pool pool1
acl splitremote
crypto ipsec transform-set client esp-aes esp-sha-hmac
interface FastEthernet0
ip address 10.97.37.212 255.255.255.0
speed auto
interface Serial0
description AIRTEL-BANG [192.168.10.2]
ip address 192.168.10.1 255.255.255.252
ip local pool pool1 10.97.37.0 10.97.37.210
no ip http server
no ip http secure-server
permit ip 10.97.0.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 3
line vty 4
password cisco
The error is while connecting to router
"remote peer is no longer responding"
please check the above said configure and confirm the problem.
change the following
the adress pool
do:
no ip local pool pool1 10.97.37.0 10.97.37.210
then
ip local pool pool1 192.168.1.1 192.168.1.110
now do the following
username vpnuser password vpn123
now when u configure cisco client vpn there is option to put the host IP which is outside router IP
and there is place to put group name and password
there where u put group name admin password admin123
then when u connect u will get a popup window ask you for username and password
put the one we have just created vpnuser and pass vpn123
u can creat more users
u need to add the following inorder to make th authentication and authorization
aaa new-model
and the FINAL IMORTANT thing is to APPLY the crypto vpn map to the interface u gonna connect to i will assume u the serial interface
interface Serial0
crypto map mymap
check it make sure all the comments are done properly then let me know
good luck
and if helpful rate
its not connecting and its shows in the router.
*Mar 3 05:31:27.633: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Aggressive mode
failed with peer at 10.97.37.83
reg,
can u post ur router config after the last change and tell me what u did u put on the on vpn client
Am using this setup for only testing VPN connection in my test lab. My local LAN IP network is 10.97.37.0/24 in the same LAN I connected one PC (IP 10.97.37.83) and installed VPN client software.
Am using for VPN client user name is admin and password is admin123.
I used pool1 10.97.37.1 10.97.37.210 network since am using the same.
Please go through my last change configuration.
AIRTEL-DELHI#sh run
Current configuration : 1514 bytes
version 12.4
boot-start-marker
boot-end-marker
enable secret xxx
enable password xxx
aaa new-model
ip cef
username manju password 0 cisco
encr aes
group 2
key admin123
domain cisco.com
pool pool1
acl splitremote
crypto map mymap 10 ipsec-isakmp dynamic dynmap
speed auto
crypto map mymap
interface Serial0
ip local pool pool1 10.97.37.1 10.97.37.210
no ip http server
permit ip 10.97.37.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 3
line vty 4
password cisco
end
but as i told u
good luck
Thanks for your support...there was a command in my router "multilink bundle-name authenticated" due to that its not working, after removing the same its working fine now....
Bye
cool i glad its working now :)
