ASA 5505 OS 8.0 VPN Not Working
Dear All
I have configured remote access VPN through ADSM wizard, but its not working. Its showing peer not responding. I am pasting my configuration below, please go though.
I will be rating for the suggestions.
sh run
: Saved
ASA Version 8.0(3)
hostname ciscoasa
enable password 2KFQnbNIdI.2KYOU encrypted
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan10
nameif outside
security-level 0
ip address x.x.x.x x.x.x.x
interface Ethernet0/0
switchport access vlan 10
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxxxxxxx encrypted
boot system disk0:/asa803-k8.bin
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_access_in extended permit ip any
access-list inside_access_in extended permit tcp any
access-list inside_access_in extended permit udp any any
access-list outside_access_in extended permit tcp any any
access-list outside_access_in extended permit ip any any
access-list outside_access_in extended permit udp any any
access-list inside_nat0_outbound extended permit ip any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool pool mask
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 101 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 101
static (inside,outside) tcp x.x.x.x https https netmask
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http outside
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh outside
ssh timeout 60
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
username cisco password ffIRPGpDSOJh9YLq encrypted privilege 15
tunnel-group test type remote-access
tunnel-group test general-attributes
address-pool pool
tunnel-group test ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
: end
The issue is:-
Aug 20 14:12:02 [IKEv1 DEBUG]: Group = test, IP = x.x.x.x, All SA proposals found unacceptable
Aug 20 14:12:02 [IKEv1]: IP = x.x.x.x, All IKE SA proposals found unacceptable!
The client and the ASA cannot agree on the Security Association options.
What version of Cisco VPN client are you using? What OS is it installed on?
I cannot see where you are authenticating a username and password? try putting in the config below and test again:-
username test password test
group-policy test-rvpn internal
group-policy test-rvpn attributes
vpn-tunnel-protocol IPSec
dns-server value <>
default-domain value <>
tunnel-group test-rvpn type ipsec-ra
tunnel-group test-rvpn general-attributes
default-group-policy test-rvpn
authentication-server-group local
address-pool pool
tunnel-group test-rvpn ipsec-attributes
pre-shared-key <>
crypto isakmp policy 10 authen pre-share
crypto isakmp policy 10 encrypt des
crypto isakmp policy 10 hash sha
crypto isakmp policy 10 group 2
crypto isakmp policy 10 lifetime 86400
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
nat (inside) 0 access-list inside_nat0_outbound tcp 0 0 udp 0
