create static routes in routers via SNMP - how ?
Aug 19th, 2008
hello
is it possible somehow to creates static routes in cisco routers through SNMP instead of doing CLI (if fx. you need to add a static route to a large number of routers) ?
I guess you have to create a RW community ?
and what tool should be used ?
that in advance for any help...
ohassairi Wed, 08/20/2008 - 00:15
  • Silver, 250 points or more
using ciscoworks LMS, go to netconfig tab and there you can create a configuration task (list of commands) and send them to a list of devices
