IPMA Console
Aug 20th, 2008
Hi all,
I'm using CUCM 6.1.2 with IPMA feature.
For Directory search, we are using a third party directory server, not a CallManagger Directory.
From the IPMA Console, I would like to force the Directory search to use the third party server and d not the native CallManager Directory, do you have any idea to do this ?
Thanks for your help,
/AN
Overall Rating: 5 (1 ratings)
a.namnami Wed, 08/27/2008 - 04:42
Thanks a lot for your response,
I'm using a CCM6.1.2 and i can't get the file "LDAPConfig.ini" :(
do you have any idea ?
Best,
/AN
