Intercluster trunk between CUCM 6.1 & CCM 4.1?
ashok_boin
Level 5
Level 5
Is it possible to establish Inter cluster trunk between CUCM 6.1 & CCM 4.1 versions.
I have gone through documentation for 6.1 but didn't find compatibility of features with other versions.
Regards...
-Ashok.
With best regards...
Ashok
Rob Huffman
Hi Ashok,
Hope all is well :)
Yes, ICT's can be configured between different versions of CCM, like in your example 4.1(x) and 6.1(x). This functionality goes back to at least CCM 3.3 that's probably why no compatibility matrix exists.
Hope this helps!
Rob
Rob Huffman
Hi Ashok,
Hope all is well :)
Hope this helps!
Rob
Thank you, Rob. It cleared my doubt.
Regards...
-Ashok.
Ashok
Rob Huffman
Hi Ashok,
You are most welcome my friend :) Glad to be of some small help.
Take care,
Rob
