tx-ring on 877
Answered Question
Aug 20th, 2008
My provider does not support Multilink PPP so LFI is not an option.
Is setting the tx-ring limit to 1 ok? I plan to use LLQ but wanted to do as much as possible to minimise delay.
Correct Answer by Steve Lyons about 8 years 11 months ago
Please refer to the following document and search for qos within the document:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/prod_qas0900aecd8028a982.html
The 870 series supports advanced qos features. The document above has many references to qos support I would recommend reviewing. You do not need to modify the transmit ring. This will be modified to a value of 2 when you enable qos and attach a service policy to an interface.
Steve Lyons - Cisco
Overall Rating: 4 (1 ratings)
Correct Answer
Steve Lyons Wed, 08/20/2008 - 16:21
  • Cisco Employee,
Steve Lyons - Cisco
