QoS configuration
Aug 20th, 2008
Hi, we are going to migrate 4507 to 6509 switches. I will be configuring this for the first time. Can you assist me in configuring QoS. The present configuration of the 4507 switch is
qos dbl exceed-action ecn
qos dbl
qos map dscp 0 to tx-queue 2
qos map dscp 16 18 20 22 24 25 26 27 to tx-queue 4
qos map dscp 28 29 30 31 32 33 34 35 to tx-queue 4
qos map dscp 36 37 38 39 to tx-queue 4
qos map cos 3 to dscp 26
qos map cos 5 to dscp 46
qos
ip dhcp pool Franklin-VoIP
class-map match-any SAP-Class
match access-group name SAP-Access-List
class-map match-any VoIP-Control-Class
match access-group name VoIP-Control-Access-List
class-map match-any Video-Class
match access-group name Video-Access-List
class-map match-any VoIP-RTP-Class
match access-group name VoIP-RTP-Access-List
class-map match-any BestEffort-Class
match access-group name BestEffort-Access-List
policy-map WAN-Input-Policy
class VoIP-RTP-Class
set ip dscp 46
class VoIP-Control-Class
set ip dscp 26
class Video-Class
set ip dscp 34
class SAP-Class
set ip dscp 18
class BestEffort-Class
set ip dscp 0
policy-map WAN-Output-Policy
set ip dscp 46
set ip dscp 26
class Video-Class
set ip dscp 26
class SAP-Class
set ip dscp 18
set ip dscp 0
policy-map DBL
class class-default
dbl
policy-map Video-Output-Policy
class Video-Class
set ip dscp 26
set ip dscp 26
policy-map autoqos-voip-policy
class class-default
dbl
The IOS file on 4507 is
System image file is "bootflash:cat4000-i5k2s-mz.121-20.EW1.bin"
The image file of 6509 is 12.2(33)SXH
Can I migrate this directly on 6509?
If no then how should I go with the configuration.
