Cisco ASA5505 Stop Responding
Aug 20th, 2008
Hi All,
I have this strange problem with one of my clients ASA5505. The problem is that it stops passing traffic and does not respond to ping. In order to fix it the client has to reboot the ASA5505, it works fine for few hours' and stops responding again.
Setup is
PCs---Ms ISA-----Cisco ASA5505----Internet.
Any ideas why the ASA5505 will stop respond suddenly? Could it be a proxy ARP issue? Is the ASA5505 somehow sees the MS ISA as a threat and not respond to it.
Thanks for your help.
Nour
Farrukh Haroon Wed, 08/20/2008 - 11:14
  • Red, 2250 points or more
There could be numerous reasons, you have to monitor the logs and other stuff carefully before anyone can help you.
However the condition you describe is quite serious and rarely occurs on the ASA "stops passing traffic and does not respond to ping".
Check the CPU/Memory/Utilization etc.
Farrukh
allen.malanda_2 Wed, 08/20/2008 - 12:43
I've seen similar issue. My client was using a syslog server whenever the syslog server becomes unreachable or freeze up. The ASA 5505 stop sending traffic to different VLANs. Please check your ASDM logs when this happen again, and post up the error message.
