Answered Question
Aug 20th, 2008
Hi all,
I am having a problem in application integration. My problem being that I have no Devicelist. When I navigate to http://x.x.x.x/CCMAdmin/reports/devicelistx.asp I get "the requested resource is not available".
Can anyone tell me how to enable this? Anything I should have activated?
I am using call manager 6.0
Correct Answer by dezoconnor about 8 years 2 months ago
Hi Jamie, the Devicelistx reports are no longer supported in CUCM 5.0 and higher.
Overall Rating: 5 (2 ratings)
dezoconnor Wed, 08/20/2008 - 07:32
Sorry Jamie, what application are you trying to integrate? What are you expecting to see from the URL you refer to?
jamieparr Wed, 08/20/2008 - 07:34
Thanks for the reply.
I am trying to intiate a simple remote execute, it falls down querying the device name. This I believe is due to there being do devicelistx webpage. When I navigate to it I get no page. I think I should see some sort of xml?
