Report for a route pattern
Aug 20th, 2008
Is there a way to get a report from CAR that would show the number of calls for a particular route pattern?
We have some route patterns that are routed to external IVRs. The call comes in on one of 5 PRI/T1 and then are routed out another port to the external IVRs.
The calls appear as Tandem calls when looking at calls for the month, but I would like to be able to pull a report for a particular route pattern or group of route patterns to see the total number of calls.
Jaime Valencia Wed, 08/20/2008 - 07:22
no, CAR does not record on which route pattern the call was placed.
if this helps, please rate
DOUG DAVIDSON Wed, 08/20/2008 - 07:34
Does it not record it on where the call was received from? If I can see the route pattern that received the call that would give me what I need.
