CUPC on virtual PC
Aug 20th, 2008
One of my coworkers is running a virtual PC on a MAC using Parallels Desktop software and we are trying to get the virtual PC to run CUPC. Is this possible?
Also will it allow a USB VTA II Camera to work on the virtual PC?
Doug
gogasca Wed, 08/20/2008 - 22:07
  • Green, 3000 points or more
It should work
Not supported... but it should A colleague had it running in his Mac same scenario
Jonathan Schulenberg Sat, 08/23/2008 - 14:31
  • Cisco Designated VIP,
    2017 IP Telephony
There is a native CUPC client for OS X. You'll have much better luck running it on the native platform.
