DNS configuration for GSS
sateeshk10
I am newbee to GSS. I would like to deploy the GSS in my datacenter.
I would like to know the DNS configuration example for domain.
ex:
www.abc.com
What records need to configured with detail script. beacause i dont have experience in DNS server configuration.
I am looking for positive update.
sateesh kumar.k
i
14 Replies 14
If you are not using GSS as primary DNS server for abc.com and just want to delegate xyz.abc.com then
On your primary DNS server (authoritative for abc.com) delegate the fully qualified domain name www.abc.com to the GSS and make these GSSs authoritative for this domain.
Following changes will be needed on the primary dns server
www.abc.com. IN NS gss1.abc.com. <-- NS record for www.abc.com via GSS
gss1.abc.com. IN A a.b.c.d <-- A record for GSS
Syed
Thanks for quick repsonse..
I need some info..
GSS01 -- 1.1.1.1
GSSS02 --- 2.2.2.2
abc.com --- 3.3.3.3
test.abc.com for sub domain IP is required? if so how to configure in DNS..
i need to put www.abc.com in NS record or plain abc.com
i dont have an any idea on DNS...
Regrds
sateesh kumar.k
If there is already a DNS server authoritative for abc.com then it should already have NS record for abc.com.
In order to delegate http://www.abc.com to two GSSs, you need two NS records on Primary DNS server and A records for the two GSSs
http://www.abc.com. IN NS gss01.abc.com. <-- NS record for http://www.abc.com via GSS01
http://www.abc.com. IN NS gss02.abc.com. <-- NS record for http://www.abc.com via GSS02
gss01.abc.com. IN A 1.1.1.1 <-- A record for GSS01
gss02.abc.com. IN A 2.2.2.2 <-- A record for GSS02
Syed
Sorry to bother you..Now i am sync...
i need to give http:\\www.abc.com or only abc.com
for sub domian also i need to do the same...
pls give the script for entire things which i have provided to you..
Do you have GSS in your netowrk?
thnkas
www.abc.com (dont use http://)
Syed
Tahnks for all your inputs..
are you useing GSS in your network...
if so could you pls give me the little idea..
i am plannning to integrate with local network and also i have gone trghgss documetns i am ok..
live how i am going to integrate..
user --- DNS -- GSS -- ACE VIP -- Domain(wwwabc.com).. is it right..
sateesh kumar.k
Typical flow is as follows
1. Client will hit their DNS servers (configured on their machines as primary/backup dns server).
2. "Client's DNS server" will query "DNS server authoritative for abc.com" for www.abc.com.
3. "DNS server authoritative for abc.com" will ask "client's DNS server" to query "GSS - Authoritative for www.abc.com"
4. "Client's DNS server" will query GSS for www.abc.com.
5. GSS will send the ip add of www.abc.com (which should be configured on ACE as VIP).
6. "Client's DNS server" will handover this VIP to client
7. Client will hit the VIP configured on ACE (for application www.abc.com).
Syed iftekhar Ahmed
its retty clear..thanks you very much..
do you have GSS live config
sateesh kumar.k
See here"
http://oreilly.com/catalog/9780596100575/index.html
There's "some" information on DNS that you can use.
This is the final script which i am going to put in my dns server
xyz.abc.com. IN NS gss1.abc.com. <-- NS record for xyz.abc.com via GSS
is it ok...
sateesh kumar.k
Do you want the two GSSs (gss01 & gss02) to abe authoritative for both www.abc.com & xyz.abc.com?
If yes then you need follwoing lines
xyz.abc.com. IN NS gss01.abc.com.
xyz.abc.com. IN NS gss02.abc.com.
Syed
no.. in between one more NS server is there which will be forwarder for these GSS..
GSS is responsible ofr A record only
flow is like this
user -- dns -- gss
can i send a mail to your personal ID..
sateesh
Sateesh
We are moving in circle with this thread.
I think you need to grasp some bind knowledge before you proceed. I would recommend reading some basic DNS theory.
If you are not sure what you are doing then there is a very good possibility of messing up your DNS server.
I am sure one or two hour reading on DNS will make you understand how to introduce GSS in your existing DNS infrastructure.
Syed
i have sent a mail to ur ID iftekhar@netpace.com
pls chk it..
sateesh kumar.k
