08-20-2008 07:17 AM - edited 03-10-2019 04:15 AM
I currently have both CSA 4.0 and CSA 5.0 management consoles installed and running from the same server (due to an upgrade). Is there a way to remove CSA 4.0 from the server without impacting the CSA 5.0 server or hosts?
If there is not a way to remove the CSA 4.0 MC software, is it possible to disable it so that it no longer operates (at an agent's/host's point of view)?
Solved! Go to Solution.
08-20-2008 02:58 PM
It's been a long time since I've done this but I believe you remove the Management Center for CSA 4.X in add/remove programs by choosing Ciscoworks and selecting the MC for 4.X as a choice when the initial dialog box appears.
There may be other ways as well but that's the only one I remember.
Tom
08-20-2008 02:58 PM
Tom
08-21-2008 09:02 AM
That will do it. I didn't realize that there were additional options, once I clicked uninstall in Add/Remove Programs.
Thanks.
08-21-2008 02:35 PM
You are quite welcome.
Tom
