WAN throughput reading
skhirbash
Would be accurate to say that the reading of the Input and Output of the WAN link interface represent the acutal throughput of the link?
Here is an example:
61444960 packets input, 3632170433 bytes,
75982428 packets output, 2708158323 bytes
Thanks in advance,
sK
Edison Ortiz
Yes, per your output, your link is 3.6Gps input and 2.7Gbps output.
You can change the interval the throughput is checked with the load-interval interface command.
Some interfaces check the throughput every 5 minutes while others check the throughput every 30 seconds. You can change this default behavior with the command mentioned above.
HTH,
__
Edison.
Please rate helpful posts
6 Replies 6
Edison Ortiz
HTH,
__
Edison.
Thanks much Edison.
SK
Edison,
Did you mean Gbps or GBps?
sK
WAN throughput is measured in bits per second so you type Gbps. GigaByte is used for storage and file transfer measurement.
HTH,
__
Edison.
rais
Level 7
Level 7
Your input should be 29 Gigabits/whatever time you have it accrued in.
Your output is 21.66 Gigabits/whatever time you have it accrued in.
bits = 8 * Bytes
Thanks.
Good catch Rais, I didn't realize he posted bytes in the first post until now :)
__
Edison.
