2960 dual purpose uplink ports
Answered Question
Hello folks, I just need to confirm the uplink ports for the 2960.
The Data sheet shows.....
WS-C2960-24TC-L
• 24 Ethernet 10/100 ports and 2 dual-purpose uplinks (each dual-purpose uplink port has one 10/100/1000 Ethernet port and 1 SFP-based Gigabit Ethernet port, 1 port active)
• 1 RU fixed-configuration
• LAN Base Image installed
Does this mean that I can only have 1 active uplink port (interface) at a time?
Or
Does it mean that I can use either Copper or Fiber at a time?
Thanks in advance I appreciate your help.
JP
Correct Answer by Mark Yeates about 8 years 9 months ago
JP,
The C2960-24TC-L has 2 dual-purpose ports which means that either the SPF or RJ-45 port can be used at one time.
HTH,
Mark
Overall Rating: 5 (1 ratings)
Correct Answer
Mark Yeates Wed, 08/20/2008 - 08:44
  • Gold, 750 points or more
JP,
HTH,
Mark
Joseph W. Doherty Sat, 11/02/2013 - 17:47
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Or one port as copper and one port as SFP.
Basically, the a copper and SFP port are paired, either of the pair can be used, but not both of the same pair at the same time.
As you have two uplinks, you have two pairs.
