Incorrect route pattern selected
Aug 20th, 2008
My one location has route patterns out of which one is local,long, international
Wwhen I make 7 digit local calls, it is not using local rp but using long distance inspite of the fact, device CSS has local partition in priority first than long distance
Here is DA for the call.
Can anyone point why it selects long and says local rp as ALTERNATE.
08/20/2008 09:13:46.052 CCM|Digit analysis: match(pi="1", fqcn="3204", cn="3204",plv="5", pss="Part-Fontana-911:Part-Line1:Part-Voicemail:Part-Fontana-Local:Part-Fontana-LongDistance:Part-Fontana-International:Part-Fontana-Internal:Part-Telescams", TodFilteredPss="Part-Fontana-911:Part-Line1:Part-Voicemail:Part-Fontana-Local:Part-Fontana-LongDistance:Part-Fontana-International:Part-Fontana-Internal:Part-Telescams", dd="93228189",dac="1")|<CLID::CCMPUB01-Cluster><NID::10.0.1.3><CT::2,100,119,1.486372><IP::10.0.2.7><DEV::SEP000DED9572AB>
08/20/2008 09:13:46.052 CCM|Digit analysis: analysis results|<CLID::CCMPUB01-Cluster><NID::10.0.1.3><CT::2,100,119,1.486372><IP::10.0.2.7><DEV::SEP000DED9572AB>
08/20/2008 09:13:46.052 CCM||PretransformCallingPartyNumber=3204
|DialingPartition=Part-Fontana-LongDistance
|DialingPattern=9.@
|DialingRoutePatternRegularExpression=(9)([2-9][02-9]X)(XXXX)
|DialingWhere=
|PatternType=National
|PotentialMatches=ExclusivelyOffnetPotentialMatchesExist
|DialingSdlProcessId=(0,0,0)
|PretransformDigitString=93228189
|PretransformTagsList=ACCESS-CODE:OFFICE-CODE:SUBSCRIBER
|PretransformPositionalMatchList=9:322:8189
|CollectedDigits=3228189
|UnconsumedDigits=
|TagsList=OFFICE-CODE:SUBSCRIBER
|PositionalMatchList=322:8189
|VoiceMailbox=5189
|VoiceMailCallingSearchSpace=
E67375C8-5665-4473-8949-0DAC99129481}
|VoiceMailCallingSearchSpace=Part-Line1:Part-Voicemail:Part-Fontana-LongDistance
|VoiceMailPilotNumber=5099
|AlertingName=
|RouteBlockFlag=RouteThisPattern
|RouteBlockCause=0
|InterceptPartition=
|InterceptPattern=
|InterceptWhere=
|InterceptSdlProcessId=(0,0,0)
|InterceptSsType=0
|InterceptSsKey=0
|OverlapSendingFlagEnabled=0
|WithTags=
|WithValues=
|CallingPartyNumberPi=NotSelected
|ConnectedPartyNumberPi=NotSelected
|CallingPartyNamePi=NotSelected
|ConnectedPartyNamePi=NotSelected
|CallManagerDeviceType=NoDeviceType
|PatternPrecedenceLevel=Routine
|CallableEndPointName=[ED20D4AD-0B98-440C-B14C-5F0E019F5C18]
|PatternNodeId=[709BCDC2-D1BE-49CB-84E7-5A312008D28C]
|AARNeighborhood=[]
|AlternateMatches=
|Partition=Part-Fontana-Local
|RoutePattern=9.[2-9]XXXXXX
|PatternType=Enterprise
|NetworkLocation=OffNet
|PatternPrecedenceLevel=PlDefaultOutsideDialtone=
|DeviceOverride=
|RoutePattern=9.@
|Pattern=(9)([2-9]X[02-9])(XXXX)
|DeviceOverride=
|TranslationPatternDetails=
|OffNetPattern=OffNetOutsideDialtone=
Michael Owuor Wed, 08/20/2008 - 10:18
  • Cisco Employee,
Hi Kadambari,
Closest-match routing is used to determine which route pattern matches the number most closely and the call is routed using that route pattern. Order of partitions in the CSS is only used to break a tie when two or more patterns in different partitions match equally.
The route pattern in the LD partition is 9.@, which includes several patterns, including (9)([2-9]X[02-9])(XXXX) which is a closer match for the dialed number than the route pattern in the local partition, which is 9.[2-9]XXXXXX.
If the route pattern in the local partition should be matched instead, change it from 9.[2-9]XXXXXX to 9.[2-9]x[02-9]XXXX. Since the device CSS has local partition above the long distance partition, the order will break the tie.
Does this help?
Michael.
Jaime Valencia Wed, 08/20/2008 - 10:33
  • Cisco Employee,
  • Hall of Fame,
    2011
some nice reading material so you understand how this works since +90% of the people think the same way you do about the order of the partitions taking always precedence
Calling Privileges in Unified CM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/dialplan.html#wp1044276
DNA is pretty useful for this
java
if this helps, please rate
