unity connection 2.1 security configuration failed
Install of unity connection 2.1 from CD is good until it gets to the end. I get a "security configuration failed" error. The security password is a strong password. The security password is used "to authenticate between clusters", however, I am only using one unit connection server. Any help with this appreciated......
nowcommsupport Thu, 09/11/2008 - 08:52
I was wondering if you have had any luck with this error. I am having exactly the same problem, and can find no answers on the net. Please let me know. Thanks.
