Meet Me Request
Answered Question
Aug 20th, 2008
hi,
i have a cluster 5.1 CCM server`s, one publisher and 2 subcriber, and i need to configure Meet me feature, how i know what`s the max number of conference and max number of user per conference,
thx
Correct Answer by rob.huffman about 8 years 5 months ago
Hi Jose,
With the Software Conference Bridge;
128 Streams
128 with 48 Users in each = 3
128 with 24 Users in each = 6
128 with 16 Users in each = 8
128 with 8 Users in each = 16
128 with 4 Users in each = 32
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
rob.huffman Wed, 08/20/2008 - 11:19
Hi Jose,
These number are for the Software Conference Bridge available on CCM :)
Cisco Conference Bridge Software
Software conference devices support G.711 codecs by default.
The maximum number of audio streams for this type equals 128. With 128 streams, a software conference media resource can handle 128 users in a single conference, or the software conference media resource can handle up to 42 conferencing resources with three users per conference.
From this good doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmsys/a05confb.html#wp1035397
The default number of Maximum MeetMe Participants (per Conference) is set at 4.
To increase the Maximum number of MeetMe participants (we have ours at 16);
Go to:
Service Parameters Configuration >Clusterwide Parameters (Service)>Maximum MeetMe Conference
Here is some additional info;
Conference Bridge Configuration
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00801ecf8a.html
Adding a Meet-Me Number/Pattern
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00801ecf96.html#76011
Hope this helps!
Rob
eljose_lol Wed, 08/20/2008 - 11:51
this is independent of type server that i am using? 7845-h2?
thx very much for de reply
rob.huffman Wed, 08/20/2008 - 12:07
Hi Jose,
These numbers are not dependant on the server model (but the 7845-H2) should serve you well in this endeavour :)
Hope this helps!
Rob
rob.huffman Wed, 08/20/2008 - 12:33
Hi Jose,
If you are wondering about the co$t for this?? This is a built-in function on Callmanager :)
Hope this helps!
Rob
eljose_lol Wed, 08/20/2008 - 12:37
Hi Rob
No, i mean the max confer and user that the 7845-h2 server can support
Correct Answer
rob.huffman Wed, 08/20/2008 - 12:46
Hi Jose,
128 Streams
Hope this helps!
Rob
roxysbrian Mon, 02/23/2009 - 14:36
Rob,
In response to your math above, is that dependent on how many MeetMe numbers are created or how many are simultaneously in use?
Brian
Jaime Valencia Mon, 02/23/2009 - 15:35
128 / Maximum MeetMe Conference Unicast value = # of simultaneous meet-me conferences.
the amount of actual meet-me DNs can be higher, lower or the same.
be aware those 128 streams are for meet-me and adhoc so if you use all for meet-me then no ad-hoc conferences can be done on that SW CFB
java
if this helps, please rate
roxysbrian Tue, 02/24/2009 - 09:14
Ok. The reason why I ask this is because we have 20 MeetMe DN's setup but can only have 6 people in a MeetMe session. I've changed the Cluster settings but it didn't make a difference. We only have a little over 200 phones registered and most of those are in our call center, so I don't think we will be having that many AdHoc conferences going on at one time.
Oh yeah, I'm running CCM 4.1.3 not 5.1.
