asa 5505, v7.2 how can i block traffic?
Aug 20th, 2008
hi, can i block the traffic between the same ports of the asa? for example, the asa 5505 has 8 ports, the ethernet port from 1 to 7, are for the inside vlan, and i want to know if i can filter traffic using an ACL between the ethernet port 1 and 2 for example...if it is, how can i do that?
the ethernet port 0 is for the outside interface.
thanks
Farrukh Haroon Wed, 08/20/2008 - 19:02
  • Red, 2250 points or more
Just put an ACL on both interfaces to block the traffic.
But make sure you permit the rest :)
You can also assign them same security levels and don't permit same-security-traffic permit INTER interface.
Farrukh
dhananjoy chowdhury Wed, 08/20/2008 - 19:02
  • Silver, 250 points or more
By default, the same security level interfaces
cannot communicate with one another.
To allow communication between interfaces of the
same security level use the command
"same-security-traffic permit inter-interface"
You can also use ACL, something like this
access-list one2two permit ip 10.1.1.0 255.255.255.0 10.2.2.0 255.255.255.0
access-group one2two in interface inside
