5510 active-standby failover
Aug 20th, 2008
I have two new ASA 5510s, with 7.2(2)10 configured for active/standby failover.
due to ASA interface limitation/availability, I am using only one interface for both LAN-base and stateful failover:
interface Ethernet0/3
speed 100
duplex full
interface Ethernet0/3.2
description LAN Failover Interface
vlan 20
interface Ethernet0/3.3
description STATE Failover Interface
vlan 30
failover is working, but I'm concern that when I enter “show failover” the firewalls don't see each other
any help?
thanks, kevin
Farrukh Haroon Wed, 08/20/2008 - 19:04
  • Red, 2250 points or more
First of all you don't need sub-interfaces if you share the Failover/Stateful interface(s). Just use Eth0/0.
Secondly is it possible to post the output of 'show failover? and if possible show run failover.
Farrukh
ksvy_ksvy Thu, 08/21/2008 - 06:11
Farrukh, I messed and didn't use:
failover key xxxxx
once I entered the key, on both, sync' come right up and all works now
thanks, for responding
kevin
Farrukh Haroon Thu, 08/21/2008 - 06:32
No problem, glad you have it working now.
Farrukh
