IP Phone 3+ minute boot up time to get an extension 6513 FEthernet blade
Aug 20th, 2008
When my IP phone boots up on this port the MAC address of the phone shows up in vlan 1 the native vlan which also is currently used for DHCP until DHCP devices are transitioned to vlan 6. The phone grabs an IP address in vlan 1. After 2 minutes or so the MAC address will also appear on the voice vlan when displaying the mac address on the port. After this occurs then the phone releases the IP address it got in vlan 1, grabs an IP address in the voice vlan and displays an extension.
I take the phone and plug into a Catalyst 3560 and the mac address of the phone shows up on the switch port it shows up in the voice vlan and the phone is ready to use in under 60 seconds.
Here's a switchport configuration on the 6513 where I plug in the test phone where the mac of the phone shows in vlan 1 then after two minutes will show up in the voice vlan.
CDP is enabled on the 6513.
Any suggestions on eliminating this behavior?
interface FastEthernet5/8
no ip address
switchport access vlan 6
switchport mode trunk
switchport voice vlan 72
spanning-tree portfast
Ship-Main-6513#sh int fa5/8 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 6 (VLAN6_Static_IP_Devices)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: 72 (VLAN0072)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Appliance trust: none
Edison Ortiz Wed, 08/20/2008 - 12:24
Eliminate the mode trunk and encapsulation dot1q.
You are using auxiliary Vlans already with the voice vlan, no need for trunking.
