Locking ACS Console on ACS BOX
Answered Question
Aug 20th, 2008
Is there a way to lock ACS console access from ACS Box itself or required to insert usename/password to Access the ACS Consoe.....
Correct Answer by chaitu_kranthi about 8 years 6 months ago
iam bit confused, wht you are looking exactly.
Let me tell my understanding on the issue.
if you are looking somthing like
ACS local page has to prompt for password. If that is right,
then create a user in the
Administrator Control page:
create a user with
Account Never Expires & Grant All Permissions.
Comeout from that page
And again go to Administration Control page
Click on the Session Policy
Uncheck the option
Allow automatic local login
Click submit
Overall Rating: 3 (1 ratings)
Correct Answer
chaitu_kranthi Wed, 08/20/2008 - 14:45
create a user with
Uncheck the option
Click submit
