how to configure ACS 4 with 802.1X
Answered Question
Aug 20th, 2008
how to configure my server ACS for supported 802.1X with order to authenticate me (PC).
thank you early
Correct Answer by dhananjoy chowdhury about 8 years 2 months ago
You can skip the certificate part.
Overall Rating: 4.5 (2 ratings)
youssef_1985 Thu, 08/21/2008 - 01:06
thank you
it is very helpful
another question :
if I want to configure my PC XP sp2 (PEAP) it is necessary to install a certificate on the ACS 4
thank you early
youssef_1985 Thu, 08/21/2008 - 10:55
thank you
if you give me an example clear you give me the pleasure and thank you for your help
