Turn off proxy arp replies for same subnet
Aug 20th, 2008
On a PIX-515 running 6(3)4 code, is there a way to prevent proxy arp responses for hosts on the same subnet? For example, one host wants to get to a website on another host on the same subnet. The first host sends a "who has" request and should get a response from the second host saying "me". What is happening intermittently is that the PIX is replying with its MAC address first. Is there a delay that can be inserted in the PIX's response, or turn it off completely for arp requests between hosts on the same subnet? I can't think of a reason why the PIX would respond.
Thanks in advance.
Syed Iftekhar Ahmed Wed, 08/20/2008 - 14:35
sysopt noproxyarp
can disable proxy-ARPs on a PIX Firewall interface.
If you disable proxy-arp, then all this does is cause the PIX to ONLY
respond to ARP requests for it's interface address. Any ARP requests
for a global IP in a static statement will be dropped.
If you disabled proxy-arp, then the upstream router (or device
attempting to contact the global IP in the static statement) must either:
a) have a route to the global IP pointing to the PIX interface as the
next hop
b) (if the global IP is on the same segment) then the device can use
static ARP entries
