ilo2 in mcs 7835
Answered Question
Aug 20th, 2008
Hello any can tell me how do to configuring ilo2 in MCS 7835 step to step and how can I work it.
How do test of ilo.
Thanks.
Correct Answer by Chris Deren about 8 years 5 months ago
As long as you put it on routable network then sure. Typically you put iLo NIC card on managment VLAN which should be routable throught the network.
Chris
Overall Rating: 5 (1 ratings)
Chris Deren Wed, 08/20/2008 - 16:20
When the server boots it gives you an option to configure iLo, I belive you need to press F6, do that and it will take you into iLo configuration, where you can set IP address, administrator name, DNS, etc. Save the config and exit. Now once the server comes up from a web browser go to https:/// authenticate and you're in.
HTH,
Chris
Correct Answer
Chris Deren Wed, 08/20/2008 - 16:26
Chris
